The larger, fourth-generation ES (designated MCV30) debuted in July 2001 for the 2002 model year.
11 Questions View all
Es300: Brake and abs lights came on
Brake and abs light in my 2003 es300 came on. I have checked the abs sensors and cleaned them, checked my brake fuid and its alright. And brake application works fine. How do i get rid of these lights?
Add a comment
1 Answer
If you believe there is no problem and you want to reset things disconnect the battery for a few minutes then reconnect. If there is no problem the brake and abs lights will stay off. If it comes back on you may have a problem and get it checked by a mechanic.
1 Comment:
Ok. Will try it and revert. Thanks
by
Add a comment
Add your answer
Brailo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 908
