The 2000–2002 Pontiac Sunfire is a sedan model.
15 Questions View all
My blower motor is not blowing air for heat or AC. I found the 30 am
My blower motor is not blowing air for the AC or heat. The 30 amp fuse in the fuse box under the hood “blows” the fuse every time I turn the blower switch on.
Add a comment
Most Helpful Answer
@dhc disconnect the blower, replace the fuse and turn the switch. If it does not blow you have narrowed it down to the blower motor. In that case replace the blower
Score 2
Add a comment
Sounds like you may need to replace the Blower fan motor or the circuit board that it is connected to. There may be a short somewhere that is causing the fuse to blow every time. Your other option is to put a larger fuse in, but that wouldn’t fix the problem.
Score 1
Add a comment
Add your answer
Dave Combs will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 743
