The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 Questions View all
1985 mercedes 300d turn signal stop
My turn signals in the dash stop working when the headlamp switch is turned on. I have replaced all the tail lamp bulbs with the correct bulbs and cleaned the contacts it did not fix it i cleaned all the grounds that i could find i repaired broken ground wires near the battery. Need some direction.
Score 2
1 Comment
The left front directional bulb was the incorrect bulb. I replaced both bulbs with the correct bulbs and it fixed it.
Thank you you guys are great.
by
Add a comment
1 Answer
Chosen Solution
How to check Mercedes W123 Fuses
Mercedes W123 Turn Signal Bulb, Front Replacement
Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement
Mercedes W123 Tail/Reverse/Rear Turn Signal Bulb Image
Guide
Difficulty:
Very easy
10 minutes
Mercedes W123 Turn Signal Bulb, Front Image
Guide
Difficulty:
Easy
10 minutes
Mercedes W123 Image
Guide
Difficulty:
Very easy
Score 4
Add a comment
Add your answer
kennethsmithea will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 363
