The Kenwood DNX571HD is an in-dash car stereo with a 6.1” wide touch screen, AV Navigation System, Bluetooth, and HD and Satellite Radio. Compatible with Android and Apple Smartphones.
3 Questions View all
Head unit will not power up.
I have a Kenwood DNX570HD that has been working fine and just stopped working. It will not power up. The red triangle is off when I start my truck however if I push that button it will light up but then goes back out after about 5 minutes.
Score 3
11 Comments
Can you please add pictures or directions of exactly which board it is and how do you remove the strips from the board
by
The daughter boards are no longer made. If anyone is interested in selling their broken units hmu huntspaintingokc@gmail.com
by
In need of a daughter board myself
by
What are you wanting for it?
by
Robert Hunt, sorry just saw you replied here I sent you an email a while back make me an offer. I don’t really know what it is worth without the daughter board working. My email is shaner12@gmail.com.
by
Show 6 more comments
Add a comment
Chosen Solution
You can actually take out the daughter board and use a heat gun to float the solder. Thats all it is 90% of the time. Just have to have a little patience and skills to take it apart.
2 Comments:
Correct..unfortunately, kenwood designed this as the farthest thing away from the fan in the whole deck. By chance do you have any idea why a similar model came with touch screen would work in a split screen mode? Half of the screen is fine and half of the screen is grayed out
by
Where is this daughter board?
by
Add a comment
Have you tried reseting it??
3 Comments:
Yes, I have tried to reset it multiple times. I have checked both fuses and also checked all connections to make sure nothing is loose or not making a connection.
by
This is all about resetingand doing a hard reset
https://www.youtube.com/watch?v=judksnNu...
by
Thank you for the suggestion. I actually used that exact video to do the reset.
by
Add a comment
Hey bud. I had one of these exact units do the same thing, so i bought one with a broken screen off of ebay fairly cheap. What the problem ended up being is called the "daughter board", which you can purchase from a site called pac parts, they run abou $145.00
1 Comment:
Pac parts offered one not too long ago. I have a broken unit with bad daughter board if you need it for anything else. aillsauto@msn.
by
Add a comment
Add your answer
Shane Houghtaling will be eternally grateful.
Past 24 Hours: 10
Past 7 Days: 76
Past 30 Days: 362
All Time: 36,593
