Repair and disassembly guides for hundreds of optical disc drives.
31 Questions View all
What external DVD drive is good for losses CD ripping?
With my current drive (Memorex MRX-650LE V7) I have had issues with 2 recent rips where there is a timing issue at 00:10:00 or 00:10:00-00:12:00. I have had this issue with Traces and the 1991 Foreigner 4 release (original tape remaster) with Foreigner 4 having the issue at 00:10:00-00:12:00 and Traces at 00:10:00. Some of my other rips may have this issue, but I am only covering the recent ones as I have noticed this persist since Traces.  I use this drive in conjunction with Exact Audio Copy.
The track on Foreigner 4 that was affected (Night Life) doesn’t have an issue I can detect as this would be very visible since I rip in WAV 16 44,100Hz quality so I believe the drive is wearing out or it’s fine, but no longer reliable for consistent CD ripping.
Is there any way I can bring this drive back into calibration or is it sound like my days of using it for CD ripping are over but as a general use drive, I’m okay? I have tried detecting the features of the drive (which also reports if it is accurate after, which it is) in some hope this fixes the problem.
Add a comment
1 Answer
Chosen Solution
Correcting the drive under drive options->Drive->Autodetect read command now fixed the problem. No errors on the second run for Foreigner 4.
It seems like the solution short of buying new externals every ~5 years as it happens (Black Friday 2015 purchase) is to run a autodetect command to bring the drive back into calibration. I don’t anticipate this working more then a few times when data accuracy is critical once it happens, but once it can no longer be recovered it’s time to start over with a new drive.
Score 2
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 19
All Time: 138
