Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
470 Questions View all
How to shut off iPhone XR with a broken screen
So I was trying to replace my broken screen, and in the process I accidentally broke it further. No big deal I thought, since i’m replacing it anyway. Then before I got all the adhesive off, I accidentally turned it on. Is there a way to either shut it off without the screen or safely disconnect the battery? Or do I have to wait for the phone to die
Score 2
Add a comment
Chosen Solution
Press vol up, then volume down then press and hold power button.
Do this until you see the screen go off, then on again then off. Usually this makes the phone stay off without itself turning on again.
Score 2
1 Comment:
this dosent work it turns back on in minuntes, esentally restarteding the phone
by
Add a comment
Just another reason why apple sucks. $1000 phone and you cant turn it off
1 Comment:
I had the same problem ….. it’s very simple make sure the screen is on then throw it down a minimum of 15 stairs and then turn screen in again if it does and put it in the sink with water at least 127 degrees for 9 minutes then go by a galaxy if you hate apple.
by
Add a comment
Add your answer
Christian will be eternally grateful.
Past 24 Hours: 9
Past 7 Days: 59
Past 30 Days: 247
All Time: 20,080
