The modern, current Toyota Tacoma - fully updated.
19 Questions View all
4wD indicator and 4 low lights on
Hello , 2005 Tacoma 4WD light and 4Lo lights blinking when ignition on . 4WD is in op. Plug in snap on scanner to data link port , and everything works fine , lights go out . Unplug scanner and lights flash immedialty
Add a comment
1 Answer
Chosen Solution
Either your front add motor is bad or the 4wd selector switch is blown.
2 Comments:
I’ll check the switch when I get home , it’s just does t make any sense that everything works as designed when I plug my scanner in , then quits when I unplug it , I’ll check the switch and the park neutral signal today
by
What was the fix? I am having the same issue right now...
by
Add a comment
Add your answer
Sean baldwin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 30
All Time: 2,992
