The Nimbus is a wireless game controller released in 2016. It is designed to be compatible with the iPhone, iPad, iPod Touch, Apple TV, and the Mac.
13 Questions View all
A button not working
A button not workimg
Score 2
1 Comment
My steelseries nimbus button “B” not working
by
Add a comment
1 Answer
Most Helpful Answer
If you have only just noticed some stickiness or you’ve just spilled something on your controller, you only need a minor cleaning around your buttons. Grab some Q-tips and some rubbing alcohol for this quick cleaning tutorial.
  1. First, unplug the controller.
  2. Dip the Q-tip into the rubbing alcohol, dabbing off any excess.
  3. Rub the Q-tip around the button that is sticking several times, getting as far into the crevices as you can.
  4. Once you think you’ve cleaned out as much as you can, press the button a few dozen times to work the rubbing alcohol into the crevice and loosening any debris left behind.
  5. If the button still sticks, repeat this process or try another method lower on this list.
Rubbing alcohol evaporates quickly and you shouldn’t be using enough to do any damage to the circuitry inside the controller. Never clean a controller with water as it can get inside and cause corrosion and circuitry damage to the controller.
Lewis
Score 3
2 Comments:
Great.. Its working!!
Thank a lot
by
can you mark it as an answer? Thanks.
by
Add a comment
Add your answer
Scott Okada will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 1,550
