The HTC Vive controller can be identified by its model number: 2PR7100. It is a first generation motion controller released by HTC on April 5th, 2016 as an accessory part of the Vive Virtual Reality set.
18 Questions View all
Connected but not getting tracked by base station
One day I noticed my controller would occasionally stop getting tracked by the base station and my hand gets stuck in the air in game. Steam Vr said it was still connected.
So I looked some things up and opened it up and unplugged and re-plugged in stuff, I’m pretty sure I put everything back but still had the same result in it being connected but not tracked.
It’s been awhile since I last tried fixing it but now been around longer so maybe there’s a new fix out there.
Score 4
Add a comment
Most Helpful Answer
Controller is not tracked by one of the base station. One of the 2 lasers of this base station is hard to see or flashing.
Is there any DIY repair for the base stations?
Score 1
1 Comment:
In this case the laser diode needs replacing. Unfortunately we don't know an off the shelf replacement for these.
by
Add a comment
Most common cause for the controller to stop tracking or have intermittent tracking is the two ribbon cables from the sensor array that connects to the top of the mainboard back out due to use or hitting walls.
Disassemble the controller and reseat these cables and tracking should return.
Score 1
1 Comment:
Thanks a lot, that was my case, I hit a wall and after that the controller stops tracking, I opened it and those cables went loose as you say, you save me, also I uninstall Gorn after that!.
by
Add a comment
I was having the same issue and this tutorial was really great at fixing it https://imgur.com/a/hKeB4
need a Torx T3, (T4/T5) personally I used a T4 but everyone says T5
and a 00 Philips head screwdriver. recommend some form of prying devices and some precision tweezers to reconnect the A5 connector
it is possible yours is still connected just loose, mine was fully disconnected.
1 Comment:
I have followed this guide exactly as shown, the two connections that are usually unplugged/loose was fully connected, I disconnected this and reconnected it still having the same issue. Note I completely took a part the saucer to examine if any sensors were damaged and everything looks as should.
by
Add a comment
I had a similar issue with mine. It was caused by intermittent interruptions from my USB drivers. Try updating your USB drivers. Also, if your motherboard is older and doesn’t have function well with 3.0, try plugging it into a 2.0 port. I know 3.0 is suggested, but plugging it into 2.0 may fix your issue if that’s what is causing the problem.
Add a comment
Add your answer
Tech Nich will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 50
All Time: 2,149
