Repair guides and support for wireless and corded computer mice by Logitech.
278 Questions View all
MX Vertical Optical Repair
Hi there, my MX Vertical isn’t moving the cursor anymore.. However, the buttons still work (e.g., left/right click, wheel, fwd/back, etc.). Does anyone know of a way to repair this?
Is the optical sensor easy to replace? Could this perhaps just come loose?
Any experience with this issue would be greatly appreciated as I haven’t seen anything pertaining to this particular mouse.
TIA
Score 2
1 Comment
Wow, thank god for the internet. This was super easy to fix once I found my super tiny electronics screwdriver. I dropped my mouse super hard and thought it was done for. So glad that this $70 mouse was salvaged from the landfill by some quick googling and helpful photos. Thank you so much!
by
Add a comment
Chosen Solution
So I figured it out. Thanks to that video provided by @justicegoat I was reassured that this device could be opened safely without breaking it, i.e., no glue.
I opened it up and noticed that the sensor was just loose and was no longer pointing to where it should be. Unfortunately the anti-stick strips couldn't be salvaged.
It was easy to clip it back in place. I had dropped this mouse from my desk enough that it must've dislodged from its clipped home. Oops.
Great mouse, though.
See images.
Score 10
6 Comments:
Thank you, thank you. Even I, a 64 year old grandma with limited tech experience, was able to fix my mouse. Thank you!
by
you save my mouse, thank you !
by
100% - -Just saved me getting a new one - was sensor that had moved after dropping it -- Thank you sir :)
by
Thanks a lot, Sir! You're a saver.
by
This worked for me too. Thanks for your help!
by
Show 1 more comment
Add a comment
Found this video, it’s in Vietnamese but it helped me open the mouse and fix that cursor issue.
turns out the lens connector was loose
Good luck!
https://www.youtube.com/watch?v=09ffN9M6...
Score 6
Add a comment
I followed @l3fl3r instructions. Thanks!
Also, by being careful, I managed to remove the anti-stick strips/skate/feet and put them back after.
Score 1
Add a comment
you can find replacement scates on aliexpress, search for ..2 Set Mouse Feet Glide Sticker Curve Edge Skates For-Logitech MX Vertical/MX Anywhere 3 Mouse M04 21 Dropshipping
Score 1
Add a comment
I don’t think you can replace the optical sensor since most mouses have it soldered on the mainboard.
1 Comment:
No, you're correct. When I contacted Logitech, to order the anti-stick pads I ruined, they only offered to replaced my mouse. So spare parts are not going to be available. But In my case, the issue was the sensor and since it was an easy fix, I can still use it. But without the pads, it's not great for anything requiring any high dpi. It'll be a donor mouse should I run into any issues with my replacement.
by
Add a comment
Add your answer
David Lefler will be eternally grateful.
Past 24 Hours: 16
Past 7 Days: 61
Past 30 Days: 270
All Time: 7,578
