Repair guides and service information for Kenmore Dishwashers
17 Questions View all
Why is the clean light flashing 4 times, blue and green at same time.
My Kenmore dishwasher model number 665.13939K013, flashes 4 times blue and green at the same time. It won’t work. Every time I touch anything or open it, it flashes those 2 lights at the same time 4 times.
2 Comments
Hi @roxned ,
Try disconnecting (unplugging) the power to the dishwasher for about 5 minutes, then reconnect the power and check what happens.
by
Thank you so much for the help. I tried turning it off for 5 minutes. Right when I turned it back on. It started beeping and the blue and green light still is blinking 4 times.
by
Add a comment
Chosen Solution
Rox - clean light blinking 4x on your model means there is an error with the wash motor circuit. Unplug or turn the breaker off for 1 minute. If it still blinks you’ll need to do some troubleshooting with a multimeter. If you are familiar with using a multimeter the tech sheet is located on the left side of to kick plate (bottom front) a screw on each side will need to be removed. Check the motor windings, all connects and any fuses.
Score 3
Add a comment
Kenmore Models without a digital display signal error codes by flashing the Clean light in a pattern unique to the error. The light first flashes the Function code, pauses for 2 seconds, and then flashes the Problem code. For example, 6 flashes followed by 1 flash (6-1) means "Inlet Water" function, "The electronic control doesn't detect water entering the dishwasher tub" problem. After a 5-second pause, the light repeats the pattern.
Can you discern what your code is?
Here’s how to do different resets on your Kenore:
https://www.hunker.com/12001704/how-to-r...
Score 1
2 Comments:
When the dishwasher is closed. When I open it, the dishwasher beeps 15 times and in between it flashes blue and green light at the same time 4 times, then pauses for 4 seconds, then repeats. The beeps are just at at the beginning and then they go away.
by
Let's see if @ladytech can help on this one.
by
Add a comment
Add your answer
Rox will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 41
All Time: 1,324
