The 360fly 4K is a camcorder capable of capturing both 360 degree and point of view recordings in 4K resolution. It can be identified by it size and weight: a 61 millimeters sphere and 172 grams.
6 Questions View all
The LEDs suddenly stopped turning on
Suddenly, all of the LEDs stopped functioning. The rest of the camera works fine and i did not have it under or near water. When i took it apart, i found that one of five of the smd LEDs on the pcb had charred lines that run into the smd. I'm not sure if it's just an smd that needs to be replaced or a larger issue. Perhaps the board is specifically for the LEDs and is fried?
Add a comment
1 Answer
Hi @myers13skulls ,
The LED, LED driver and associated components (bit hard to see in the pic what is missing in comparison to the other LEDs) is certainly damaged and/or burnt out.
Could be just component failure that caused this. Certainly looks like excess current flow through the components.
Try searching online for (insert "board" number of LED board) schematic to hopefully find a schematic diagram of the pcb which will make it easier to diagnose if anything else is faulty or what may have caused this to happen.
Alternatively, this may be an option to consider, if you can't find the schematics and the price is right.
Add a comment
Add your answer
Michael Myers will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 151
