{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
277 Questions View all
MacBook Pro 2017 screen flickering / glitching / has horizontal lines
My macbook pro screen has started started glitching all of a sudden and I am unsure why. I have tried the following :
  • Restarting
  • Resetting SMC
  • Adjusting display settings
Does anyone have any other solutions for this issue?
Score 8
4 Comments
Can you post a few pics or vid so we can see what up Adding images to an existing question
by
@danj Hello Dan, I have added some now
by
My MacOS screen now very bad in 18%
Ther some: Flicking, Glitch, Bad Quality, Many Black Screens, Lags and Viruses
by
I hаd a similar іѕѕuе, Mу Mac had flickering lines.
Fіnаllу I mаnаgеd to resolve thе problem after doing some research.
Follow thіѕ guide hеrе: https://smarturl.it/MacFlicker
Hope thіѕ helps
by
Add a comment
Chosen Solution
Not good ;-{
Your T-CON board has failed likely from over heating. Either you tend to use your system on your bed or rug which blocks the vents or you run your system hard playing heavy graphics games or video editing.
Here’s the needed part MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and here’s the guide MacBook Pro 13" Touch Bar 2017 Screen Replacement
MacBook Pro 13" Retina (Late 2016-2017) Display Assembly Image
Product
$454.99
Score 2
Add a comment
Hi Dan,
I just started having the same issue, so thank you very much for the answer. I have almost no doubt I’ve overheated the TCON board. I have some follow-up questions, whenever you can:
  1. Do you have some idea how much Apple would charge to make this replacement out-of-warranty?
  2. Are the 2020 Macbook Pros (13-inch, Intel i5 processor) set up the same way internally, i.e. with the TCON board between the heat sinks? And are they any better at not overheating? I guess another way to phrase this question is, are the newer Macbook Pros any better at avoiding this issue?
  3. I will definitely look to install a temperature monitor in the future...what is a safe range to have the temperature to avoid running into this issue again?
Totally understand if you're not in the place to answer some of these questions. Any help would be greatly appreciated!
One more quick question: is this issue one that tends to build up over time or can happen in one instance of misuse?
I'm just trying to self-diagnose what processes may have led to this happening.
Add a comment
Add your answer
Sunny Lee will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 56
Past 30 Days: 240
All Time: 23,702
