Refrigerators produced by Samsung.
259 Questions View all
Bi- metal thermostat, heaters, timer
I would like you to answer me something. (Still on my first question.) Model number of the fridge is RT31FAREDSA Samsung Double door.
1. How do remove the bimetal thermostat from the heaters
2. If I measured the heaters and bimetal thermostat still attached together and got a reading of 433 ohms
What does it mean, is my heater faulty or not
3. How do I unattached the bimetal thermostat from the heater
Please some answers
@jeff
Thanks
Update (07/08/2020)
Update (07/09/2020)
@jayeff
The two arrows on that image show the two brown wires of the heater and the bi-metal defrost thermostat. They can't be separated for i have tried it and nothing seems be a seperating point so I had to measure them after I had to remove the ice
So what I am not shure of is weather the thermostat was in its opening or closing point because it came up with the same reading but now caring with a -1 of the other result
Your last comment you talk of the thermo bi protector which is really confusing me now coz if it's a protective where/which is the thermostat now ?. Another question @jayeff is where can I get the timer of the particular fridge
“Maybe” the problem is the timer since the cycle is incomplete.
Thanks
Be blessed
Score 1
1 Comment
[image|2153559][image|2153525]
by
Add a comment
Most Helpful Answer
Hi,
I don't know the fridge and cannot find any parts information for it, but it would be unusual for both the heater and the defrost thermostat to be connected together unless the thermostat’s contacts are used to disconnect the heater and maybe the control board detects the change in resistance on the heater circuit and stops the defrost cycle and starts the compressor and evap fan again. This is only conjecture on my part as I said, I don't know.
Are you sure that it is a Bi-Metal thermostat and not a thermistor? Are there any component markings on the case that may help to identify what it actually is? Does the resistance change if the “Bi-Metal thermostat” is allowed to get to room ambient temperature and is not at the temperature of the evaporator unit which given how much ice was on it would be close to <0-10 deg.C? If possible, maybe hold your fingers on it for a while to warm it up and then check the resistance. Watch out that you don’t get ice burns and also do this with the power disconnected from the refrigerator.
Bi-Metal defrost thermostats are a simple device. Just two dissimilar metals that depending on the type of thermostat either move away or move towards each other as the temperature changes thereby either making or breaking a circuit connection, i.e. either open circuit or short circuit. Their design specification dictates at what temperature the contacts actually make or break. There is no external electrical power input required to make the thermostat function. It is solely due to the temperature of the environment where it is located.
Post some images of the heater/defrost thermostat arrangement and perhaps it can be worked out as to how and why they're wired as you say.
Update (07/09/2020)
Hi,
OK
It’s a bit hard to see exactly as I can’t see where the wire at the other end of the heater is connected to.
This is what the heater should look like.
Here’s where I think the heater is and also one wire from the heater
(click on image to enlarge for better viewing)
You need to find the wire at the other end of the end of the heater (see the link above and see where it is as I can’t see it in the images) and then disconnect the plug connector where the heater wires connect (the one shown in the first image you posted and also in the image I posted with the yellow insulation? on it) and then place the probes directly where the brown wire is and also where the wire from the other end of the heater is in the plug and check the reading.
As best that I can find out is that a P-5M1N is a THERMO BIMETAL-PROTECTOR 125/250V,10/5A,100. I’m not sure what the “100” refers to but it is designed to carry at least 5A if the voltage is 250V AC where you are so maybe the heater does go through the thermostat, but it will not have any resistance. It is just a switch and should have no resistance or at best <0.1 Ohms.
Depending on what the voltage supply is where you are if the thermostat is in series with the heater and its’ rating is as shown then if the maximum current was flowing through the thermostat to power the heater then 125V with 10A = 1250W of power and the heater’s resistance would be 12.5 Ohms. If it were 250V with 5A = 1250W of power and the heater’s resistance = 50 Ohms. Even if the heater’s wattage was only rated at 625W the resistance would then be 25-100 Ohms.
Either way the heater’s resistance is between 12.5 Ohms and 50 Ohms and not 433 Ohms. To get 433 Ohms @ 240V AC= 130W which is little better than a light bulb as far as a heater goes and also it would mean only 0.5A current flow. Manufacturers wouldn’t put in a thermostat with a rating of 5A for a 0.5A current flow just on the cost difference alone..
So it could be the thermostat (high resistance contacts?) or the heater. You would have to isolate them from each other and then test them individually to know.
I suspect that the thermostat should test open circuit at temperatures above 0 deg. C as most thermostats operate to signal the control board when this temperature is reached. In your fridge perhaps if it is wired in series with the heater then it is used to cut off the power to the heater.
The thermostat should measure short circuit i.e. 0.00 (zero) Ohms at temperatures below 0 deg. C so that when the auto defrost cycle is commenced the next time the heater circuit has been reestablished by the fact that the thermostat has closed again when the temp was below 0 deg C as the freezer would be at -18 deg. C at the start of the defrost cycle
Score 2
2 Comments:
@jayeff
It's a bi-metal defrost thermostat, am Shure
It has two pcb boards
The main pcb and the sub
An external sensor, the defrost sensor, the knob sensor in which are all working
The bi-metal defrost thermostat is attached to the heaters the description of t is
PW-15M1N
60/40
145
I have tried to upload the photos but all in vain
Thanks Jeff
by
@jayeff
Actually
The photos have been uploaded
Please check for it
It's not a full version of it but you can take a glimpse of the heater and the connected bi- Thermostat
by
Add a comment
The bimetal thermo disc is connected in series with the heater thus the wire that connect the heater to thermo disc if cut will sepatate them. The thermo disc is normaly open it will only close to activate the heater during defrost cycle. On the other hand the thermostat controls the temperature during the cooling cycle.
Add a comment
Add your answer
atuhutrire alison will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 19
Past 30 Days: 68
All Time: 1,973
