Repair guides and information for the Nintendo Switch Joy-Con controllers.
168 Questions View all
Joy Con still drifts just after replacement
I had a really bad up/left drift problem on my left joycon, so I ordered the repair kit and followed the guide. After replacing the stick it now has a slight downward drift problem, noticeable in calibration and while playing a game (tested game was Animal Crossing New Horizons, the character would slowly move downward when the stick was not being touched)
Score 9
Add a comment
Most Helpful Answer
Make sure the ribbon cable and the connector for the joystick is clean. Contaminants there can sometimes cause drift
Score 2
Add a comment
Did you try updating controllers? It worked for me
Score 2
Add a comment
As well as the 2 answers above you can also try re calibarating the joy con and lastly reset the console by holding down the power button for 10-12 seconds. Usually the 4 things mentioned here combined will sort it out. Changed about 5 sets so far and no issues now
EDIT Sorry didn’t fully read your question seems you did calibarate it already. So it could be the housing around the joystick has become dislodged. You cant also rule out that the replacement stick is just faulty. Usually in those kits you get 2 or 3 sticks so try another.
Score 2
Add a comment
Add your answer
Falling Rose will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 82
All Time: 5,874
