6th generation Android smartphone designed by Google and manufactured by LG. Model LG-H790. Released October 2015.
89 Questions View all
Thermal Pads for Phones
Hi guys, so right now I’m doing a screen repair on a Nexus 5X and I’ve realized that there is a thermal pad on the phone’s screen assembly (see picture). I don’t think I can transfer this pad without breaking it so I was wondering which thermal pad should I buy.
Is it fine to use pads that are for PCs eg. GPUS?
Should I be buying 0.5mm thickness or 1mm thickness?
Are AliExpress/eBay thermal pads fine to use.
eg. ++https://www.aliexpress.com/item/32716660...
++https://www.aliexpress.com/item/32839304...
Thanks.
1 Comment:
The thermal pad on the screen is the yellow square.
by
Add a comment
1 Answer
If you have a lot of space use 1mm which would dissipate the most heat but if you only have a limited amount of space then go for 0.5mm and I think you should read the reviews before buying the thermal pads
Add a comment
Add your answer
Hairy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 15
All Time: 268
