The first generation Neon was introduced in January 1994 and manufactured until August 1999. It was available as a four-door notchback sedan and a two-door notchback coupe.
29 Questions View all
speedometer does not work
speedometer does not work checked codes had p 0500 (vss bad ) replaced vss still not working (no codes ) replaced instrutment cluster .still not working .replaced engine computer .still not working . replaced connector to vss .still not working . any ideas ?
Add a comment
1 Answer
Most Helpful Answer
Have you checked the output gear on the transaxle to see if the gear is damaged or broken. It sounds like it's not spinning the sensor.
Score 1
Add a comment
Add your answer
Dale Packard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 45
