Model A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
50 Questions View all
How do I upgrade my mid 2014 21.5 iMac?
Hello, I have a mid 2014 iMac 21.5 inch and was wondering how much I can upgrade? I only have the 1.4 GHz Dual-Core Intel Core i5 cpu. I want to upgrade everything to make it last as long as possible. can I put a 4k screen in?
1 Comment:
Add a comment
  • This systems RAM is soldered! So you are stuck with the 8 GB it offers
  • If you have a HDD model you won’t have the PCIe blade SSD connector and its support logic so that rules out any performance improvements by adding a faster SSD drive
  • The CPU is also soldered down so you can’t upgrade it
  • This system can’t support an internal 4k display either!
Basically, it is the least upgradable system Apple made!
So the only thing you can improve is swapping out your SATA III (6.0 Gb/s) HDD to a SSD. Here’s the guide to do that iMac Intel 21.5" EMC 2805 Hard Drive Replacement. If you have a PCIe blade SSD only system you could add in a HDD or a second SSD.
If you happen to have gotten a Fusion Drives system then you could replace the impish 128 GB blade SSD to a more sizable blade SSD (500 GB to even a 1 TB) as well as breaking the Fusion set so you end up with a true dual drive setup which will get you even better performance! iMac Intel 21.5" EMC 2805 Blade SSD Replacement
Frankly, I think finding a used Mid 2017 21.5” would be a better and cheaper direction iMac18,2 - 21.5” 4K iMac Core i5 3.0/3.4 GHz or a i7 3.6 GHz as you are also looking for a 4K system.
iMac Intel 21.5" EMC 2805 Hard Drive Image
Guide
Difficulty:
Moderate
40 minutes - 1 hour
iMac Intel 21.5" EMC 2805 Blade SSD Image
Guide
Difficulty:
Moderate
30 minutes - 1 hour
Add a comment
Hey Dan,
Thanks for this post! I also got a mid2014 imac (i5 CPU) recently and i was wondering if I could swap out the internal components with another imac that was damaged?
Thanks in advance.
1 Comment:
Best to create your own question listing out what you are thinking of re-using in the other system. Make sure you tell us the exact models involved
by
Add a comment
Add your answer
Nick Crill will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 45
Past 30 Days: 181
All Time: 7,499
