Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1709 Questions View all
Why is my ice maker leaking
My Kenmore refrigerator model 596.72003014 is making ice just fine. However, recently I noticed it was leaking water into one corner of the ice collection bin, which is then freezing into one big hunk of ice.
Add a comment
1 Answer
Chosen Solution
If the ice cubes are stuck together in a row when they first fall, then the ice maker is over filling. If only a few cubes are together, your ice maker might not be level. Or, your ice maker seals are bad causing the water to leak out.
You would need to watch the the ice maker as it’s filling to determine what is causing the water to get in ice bin.
iFixit Staff Suggestion: Check out the Ice Maker Leaking wiki for other fixes.
Score 3
Add a comment
Add your answer
kreager1 will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 85
All Time: 1,345
