The Chevrolet Aveo (T200) is the first generation, a subcompact automobile manufactured since 2002 by Daewoo — originally marketed as the Daewoo Kalos and prominently marketed as the Aveo.
26 Questions View all
Front left power window can roll down but it cannot roll up,
My Chevrolet AVEO LS . Front left power window can roll down but it cannot roll up, and does not respond from drivers main switch at all,not even going down.After proper testing of both F/ Passenger and main switch driver side found both working switches in good working order.Any advice or suggestions please. It is a 2007 Model
2 Comments
Hi,
What is the year model of the vehicle?
by
If I fully understood, your wheel drive is in the right, and the switch near the driver don't work on the window of the left side and the switch on the left side only roll down the front left window, is that correct?
by
Add a comment
1 Answer
Most Helpful Answer
Hi,
Here’s the Chevrolet Aveo 2007-2010 Factory Repair Manual
Scroll down and click on Schematic and Routing Diagrams > Fixed and movable windows, then pass the security test to view the schematics for the power windows.
Use the schematics to check if there is power available at either the driver switch or the passenger switch to operate the window regulator motor in both directions. The wire colours are shown on the schematic
If there is power at the passenger switch then click on Main Contents > Interior trim and paneling to see how to remove the door trim and then click on Main Contents > Fixed and movable windows to see how to access the power window regulator(see p.27 of 44) to see if the regulator motor connections are OK etc.
Hopefully a start
Score 2
Add a comment
Add your answer
Rudi Le Roux will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 26
All Time: 2,093
