Self-priming automatic electric pumps with helical gears, produced by Marco.
28 Questions View all
Pump in alarm after 40 sec
This weekend the pump was installed and it appears that after 40 seconds the pump goes into alarm? We have checked everything carefully, water supply OK, venting OK?
When the pump goes into alarm, the yellow and blue light flashes, which alarm is that ???
3 Comments
Hi @patrickdl ,
What is the model number of the pump and what is it connected to?
by
@jayeff
Model nr.: 16468115
The pump is connected in a boat at 12V .
After 40 sec running it stops and give the alarm yellow , green / bleu light , after reset it works again .
You want to take shower it stops again ?
Regards ,
Patrick
by
Elektronische drinkwaterpomp UP12 / E
Punt nr .: 52205
Model nr.: 16468115
EAN / productcode: 8022278609626
by
Add a comment
1 Answer
Most Helpful Answer
Hi @patrickdl ,
I assume that it is a Marco UP12E, is this correct? According to p.12 of the user manual there are two warnings that use both LEDs. One says that:
Yellow and blue LED that blink together indicate that the power supply is providing the wrong voltage. Please check to have the correct wire section for the power supply and a charged battery, if present.
See table on p.13 regarding the wiring specifications If the wiring is not adequate there may not be the correct voltage at the pump terminals.
Score 3
Add a comment
Add your answer
Patrick De Laet will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 89
