Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
31 Questions View all
Can I remove logicboard and put it into A1599 housing? (IPAD mini 3)
Hey guys,
I’ve got a scenario here.
If I take the logicboard of an Ipad Mini 3 (Model A1600; wifi + Cellular), would it work if put it into the housing the IPAD mini 3 (Model A1599; just wifi) ?
I just want check if this is doable.
Thanks
Score 1
Add a comment
1 Answer
Chosen Solution
This isn’t something I have tried myself but I suspect it would. The iPad mini logic boards aren’t screwed into the housing like iPhones are so you don’t have to worry about proper placement of screw holes. The main difference between the two versions of logic board is that the WiFi only board has a large hole where the RF infrastructure would be. All of the other flexes are universal.
So if you already have the two boards, I would certainly give it a try.
iPad mini 3 (Wi-Fi) Logic Board Image
Product
$69.99
Score 3
Add a comment
Add your answer
Ckalable upflow will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 255
