Refrigerators produced by Samsung.
259 Questions View all
Every 3 weeks our refrigerator fan freezes and starts making noise,
Every three weeks Our Samsung Side by Side Refrigerator starts making noise. I have to take everything out of the fridge for 12 hours (Keeping everything in the freezer during that time), then I put everything back in the refrigerator and everything is back to normal. Something is causing our blower fan in the refrigerator to freeze, once I unfreeze it everything is fine for another 3 weeks or so. I would like to have it repaired but sometimes service personnel need a little help diagnosing the problem so I wanted to find out what was wrong so I can tell them what needs to be fixed.
Score 1
2 Comments
I have the same problem
by
We have this same issue also the ice maker freezes up even after being replaced and sealed as per their fix.
by
Add a comment
Most Helpful Answer
Hi @samsungbonnie ,
What is the model number of the refrigerator?
It sounds as though the evaporator fan in the refrigerator is being frozen over due to a problem with the auto defrost in the refrigerator compartment.
Given that you say that it occurs in the refrigerator compartment, your model is probably one that has two evaporator units. One in the freezer and one in the refrigerator whereas a lot of side by side refrigerators only have the one in the freezer compartment.
Search online for Samsung (insert refrigerator model number) parts to find suppliers that may have parts diagrams that can verify this. (partselect.com and searspartsdirect .com are two that usually do have these)
Also search for Samsung (insert refrigerator model number) service manual. Sometimes you can be lucky and find the service manual (for free) and this details how to run diagnostic tests which may also help to know what is happening
Defrost problems can be caused by a faulty defrost heater, located beneath the evaporator unit, a faulty defrost thermostat which is used to signal when to end the defrost cycle, a blocked drain which leads from under the evaporator unit to the evaporator pan under the freezer compartment near the compressor unit or a faulty control board which initiates the defrost cycle.
Not sure how often a refrigerator defrost cycle occurs but a freezer defrost cycle occurs approximately once every 10 hours to melt the ice build up on the evaporator unit allowing it to drain away. After 10 hours of normal operation there really is not that much ice build up anyway or not enough to freeze over a fan which is located near the evaporator.
Score 5
2 Comments:
Is there a way to check if it's defrost heater or sensor?
by
@vanowm
You can test the heater with an Ohmmeter to make sure that it has continuity. Disconnect the power from the refrigerator and then access the defrost heater which is located under the evaporator unit. Unplug it from the wiring harness and then use an Ohmmeter to measure it resistance. i don't know what is should be , but it shouldn't be open circuit.
As for the defrost sensor or thermostat it may depend on what type it is. If it is a bi-metal thermostat you can test if its contacts operate and release OK again using an Ohmmeter. If it is a thermistor you can test its resistance as well but a thermistor's resistance varies with temperature so this will be harder to know if it is OK
by
Add a comment
I have seen a number of refers build up ice over a long period (weeks) and it was caused by leaking door seals. This mostly happened in the freezer section, but could be in the frig section also.
Score 1
1 Comment:
I can't tell you how many calls I've gone on for reach in coolers/freezers, and even walk-ins, where we defrost the coils, verify defrost is working, then diagnose the door seals as bad. Replace them and boom its good. Always check door seals!
by
Add a comment
Probably needs a heating coil. If you see frost building up too much that’s a sign that the heating element is bad. But you may have to unscrew the back panel in the freezer to see it. It should have some frost but not loads of ice build up. The heating element is at the bottom of the aluminum coils in the middle of it and goes up the sides a few inches generally. It can be tested with an ohlm meter if it’s good or not.
Add a comment
There is a thermistor on the evaporater line that needs moved over to the other line. It is sometimes faulty but no all the time. It is not staying in defrost long enough. Remove the plastic cover on the back wall. All the ice should be removed and then move thermistor. Usually has yellow wire and a small clip to attach to the copper line.
Score -1
Add a comment
Add your answer
Bonnie will be eternally grateful.
Past 24 Hours: 18
Past 7 Days: 194
Past 30 Days: 940
All Time: 29,998
