All screwdrivers manufactured by iFixit and sold on iFixit.com
22 Questions View all
T6H, T7H, T8H, T9H, T10H - vs - TR6, TR7, TR8, TR9, TR10
Is the T6H, T7H, T8H, T9H, T10H -bit identical to the (torx security) TR6, TR7, TR8, TR9, TR10 -bit? And what is the reason for the difference in naming?
I’m deciding whether to buy a precision screwdriver kit.
T[…]H:
vs TR[…]:
Score 3
1 Comment
The only difference is the security screws have a pin so the Torx TR bit have a hole to get around the pin, unlike the standard Torx drivers which don't.
by
Add a comment
Chosen Solution
The difference is the T6H is the torx security bit, and the T6 is the regular torx bit. I think you can use the torx security bit in the regular torx, but you definitely can’t use the standard torx driver in the security screw.
Score 2
6 Comments:
My question is if (for ex.) the bit labeled as T6H is the same as one labeled TR6.
by
@Professional Amateur They’re not. The H one is the security bit, the non H one is the standard bit.
by
It's a matter of terminology, just observe the bit itself -- does the Torx bit have a hole in it? Then it's a Torx security bit. T6H (H probably means 'hole') and TR6 (tamper-Resistant) are equivalent.
by
It looks like the answer is yes but no one is giving a definitive answer. Simple is a TR8 the same as a T8H?
by
@oldturkey03 Seems like you are wrong if you look at the post below. And you did not give a definitive answer either.
by
Show 1 more comment
Add a comment
Hello,
I just bought a set containing T6H and T8H bits and I can confirm they fit the TR6 and TR8 Torx Security Screws from the Mac Mini Late 2014 Hard Drive Replacement instructions. The T#H bits have a little divot in the center that accommodates the nib in the center of the security screws.
Does the "R" in TR6 mean "Regular"? Or does the "R" designate that it's a security screw? I have no idea and I wonder if some of the confusion on this thread stems from that "R". Regardless, the T#H bits do work with security screws.
Score 1
Add a comment
Add your answer
Professional Amateur will be eternally grateful.
Past 24 Hours: 24
Past 7 Days: 125
Past 30 Days: 644
All Time: 17,716
