Released in March of 2014, can be identified by the model number KX-TGE233 on the bottom of the main docking station.
9 Questions View all
What is wrong with my telephone line?
Phone is plugged in, phone line connected to modem, and screen says “check tel line.” I have unplugged phone for 30 min. No change. I have disconnected phone line from modem. No change. I have reset the modem. No change.
It is a Spectrum modem.
Add a comment
1 Answer
First of all, make sure that your landline is set up correctly and plugged in securely. If you have DSL High Speed Internet, you will need a DSL filter (Not included with product).
Second, If that is all fine, check that the phone is powered on and not dead. Make sure the battery is inserted the correct way.
Third, try resetting the phone by unplugging all cables and batteries for 1 minute, then plug it all back in.
If none of the above work, you may have a faulty phone, and it will need replacement, as there is no other way to fix this. Hope this helps!
Add a comment
Add your answer
Linda Thurston will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 1,007
