No power
Dear all,
my beloved PowerBook Titanium does not want to power up. Battery is ok as well as power supply. Any idea?
Dear all,
Try looking here: http://support.apple.com/kb/HT1431#faq8
Resetting the PMU might do the trick. I know the ol' Titanium is sweet, but it also might be time to look at a newer model.
It could be your DC-in board. The best way to test it would be to slide in another battery that has a charge to it... if the computer turns on, it is most likely your DC-in board. You can purchase one here if you are interested:
[linked product missing or disabled: IF133-010]
And you can look at the repair guide here:
Beware Tyler's solution does not apply to the Mercury Model. The Mercury doesn't have a separate DC-in board.
Try taking out your PRAM battery, shown in the remove PMU guide (it's the big thing marked 616-0114-A)
Disconnect the tri color lead from that to the PMU, start up the PowerBook (it should now work), then reconnect that cable and hopefully you should be left with a functioning PowerBook !
So, disassemble to step 16, disconnect the tri color lead, reassemble, turn on computer. Disassemble to step 16, reconnect tricolor lead, then reassemble? Is that correct? Why would this work?
Okay, will give it a shot: https://www.youtube.com/watch?v=TIN6kMix...
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 7,312
1 Comment
Have the same problem. Tried resetting and still nothing.
by Simon
