My battery corroded the main connectors. Can it be repaired?
While in docking port, ERR 3 the battery corroded the units main charge connectors. I tried reaching it with q-tip with vinegar, but it qasnt enough so it will require a full breakdown. Do you repair?
Add a comment
1 Answer
almost anything is repairable. 1st, can you get the parts required: 2nd can you get the tools required: 3rd can you find directions needed:
For battery contacts, vinegar and sandpaper work unless the contacts are eaten away.
Add a comment
Add your answer
Robin Harper will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 240
