Released in May 2020, the 13" MacBook Pro features quad-core Intel 8th generation Core i5 and i7 processors, and Intel Iris Plus 645 integrated graphics. (Model A2289/EMC3456 with two Thunderbolt 3 ports)
80 Questions View all
Any advice on removing the back cover of this machine,
I have tried multiple things including a suction cup, some old credit cards, my fingernails, and a stiff plastic straw, I ordered some actual pry tools to see, but I feel like I will still have issues, I have gotten a good amount of clips off but it is not a big enough gap the grab the button cover from the the trackpad area and pull forward
Add a comment
1 Answer
Chosen Solution
The trick is to slide the bottom cover to the front and then lift.
I sometimes find junk has gotten into the grove area which stops it from sliding forward. I do two things I use strong duct tape to create a handle to pull forward on the front half of the cover and leave space in the center for a good suction cup to pull up and a second set of hands to hold the system. Then dripping some isopropyl alcohol along the left and right side gaps to help break the seal.
Update (06/03/2021)
13” model
Score 2
8 Comments:
So it seems for me what is stuck is the slide in tabs, I am unsure how to get them dislodged, I also noted that the model shown in the picture is a 16 inch, however I am almost 90% sure the 13 inch has the clips as well
by
@gamerchapet - It's the same setup! Look at the added image
by
@danj Ah so looking at that all I have it the two "Drop in Tabs" the rest is dislodged, but I have no idea how to get the drop in tabs to let go, so I can move the back cover off
by
@gamerchapet - Slide and lift and slide a bit more. The middle drop in tabs need the lift.
by
I manage to get it removed, now I am stuck on the part of putting it back, I am pretty sure it's just a matter of lining it up, just taking forever to line up. (Why did they move to this from the 2015 drop in design) *sigh
by
Show 3 more comments
Add a comment
Add your answer
Skylar will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 138
All Time: 675
