Released in November 2017, the Oppo F5 is the first smartphone to use an 18:9 display instead of 16:9. In spite of having a 6.0-inch screen, the F5's width is similar to the 5.5" display with 16:9. Models CPH1723 and CPH1727.
43 Questions View all
How can you download Google Services Frameworks?
I accidentally deleted my Google Services Frameworks cause I was cleaning cache that time and now I can’t download it properly because It says “Network Anomaly, Please Check the Network Status and Try Again.“ even if my data is on. (I use data, too broke for wifi.)
Here’s the problem; It’s been a few months ever since my phone isn’t update. How can I update/download apps? My google services frameworks is gone! I’ve tried some solutions that can work but none of them did a single thing. For example; I tried using somebody’s wifi, the answer is still “Network Anomaly, Please Check the Network Blah blah blah.“ Second, I tried to follow a google instruction but the steps is not working for me. Third, I tried to restart it but It will risk my Accounts, pictures (School Purposes) and other important stuff I have on my phone so I backed out.
What do I do..? Because of this my grades dropped cause I can’t enter a follow up from my teachers cause they use Google apps for the follow up..
Score 9
Add a comment
1 Answer
Hi @kim_yoshi ,
Perhaps the easiest thing to try is to factory restore the phone. As Google Services Frameworks is a core part of the Android OS it will be reinstalled with the restore.
Be aware that a factory restore will erase all your data and downloaded apps and will restore the phone to its last updated condition. Backup the phone to a PC before performing a factory restore.
You can either use the factory restore feature found in Settings (backup is also there) or use the hardware keys to perform a hard reset
You will need to know the Google User ID and password for the phone if it has a Google account to access the phone after a factory restore as the FRP lock feature (factory reset protection) will have been enabled.
When the restore has been completed go online and try updating the phone and then the Play Store app (Open Play Store app > Settings > About).
Then try restoring your previously backed up data from the PC by using the restore feature in Settings. This setting is different to factory restore
Alternatively you could try and download the Google Services Frameworks apk file from various websites online, to a PC and then sideload the .apk file into the phone from the PC and then install it in the phone. The problem with this is you have to get the .apk file version that is compatible with your phone and the Android OS version that is installed on it, otherwise it won’t install.
Add a comment
Add your answer
Kim Yoshi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 102
All Time: 3,163
