V-Moda M-100 headphones - sound in only one ear
I have a set of V-Moda M-100 headphones, brought in 2014, so out of warranty. Just yesterday the sound stopped coming out of one side. Wondering if a repair is possible. Thanks for any ideas!
Add a comment
1 Answer
Chosen Solution
Rick Slick, probably. Most common here would be a bad headphone jack or a bad speaker (driver) Jiggle and bend the wires at the jack and see if that makes a difference. If it does not, use a multimeter and remove the cover from the speaker part of your headphones. Check the wires between the jack and the speaker for continuity. Let us know what you find and for any issues you can post pictures with your question. Adding images to an existing question
Here is the guide that will show you in principal how to replace the jack How to Replace the Audio Jack
Skullcandy Lowrider Image
Guide
Difficulty:
Moderate
30 minutes - 1 hour
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
Score 1
1 Comment:
Thank you! :)
by
Add a comment
Add your answer
Rick Slick will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 49
All Time: 1,103
