Charging station for the Dualsense PS5 controller.
3 Questions View all
How to remove the white side plates
The dualsense charging station has white side plates like the Playstation 5 console. I want to paint them black, so I was wondering if there was a way to remove the white plates. There are no visible screws. The whole thing seems to be glued together.
Score 2
1 Comment
did you ever find a way?
by
Add a comment
Most Helpful Answer
If you turn the charging station upside-down, on the bottom plastic you will see two edges which connect to the inside side and top plastic which is one moulding. Pry the bottom plastic off (it's just clipped) and then undo the screws and the white side plastic comes off.
Score 2
Add a comment
See my teardown over at Dualsense Charging Station Tear Down Guide
Score 2
Add a comment
Add your answer
Sulakshan Rajaratnam will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 28
All Time: 955
