Also known as the Mega Drive II, this is a smaller, lighter, 2nd-generation version of the popular Genesis console, released in 1993.
11 Questions View all
Sega Genesis 2 will not boot, even though the power light comes on
My system worked fine recently, but today I powered it up and the BIOS screen wouldn’t show up. I disassembled the system, and all the inputs seemed to be soldered correctly. Is there something I might have overlooked, or might it be something related to the A/V cable? (The cable is an RF modulator cable, by the way.)
Score 1
2 Comments:
Can you open up the unit? Does the motherboard smell like fish/fishy? Bad caps are a common problem on Genesis/Mega Drive units.
by
@andrewsawesome I'm currently away from home, but when I get back on the weekend, I'll give it a check. I opened it up, but I didn't think to smell it.
by
Add a comment
1 Answer
There might be something really wrong with your motherboard. Take apart the console and check for grime, dead or corroded caps, and corrosion. Maybe check the CPU/GPU?
3 Comments:
When I took it apart, I didn't see anything wrong with it.
by
Try replacing the caps. The caps might be dead entirely.
by
Also, there might be something really wrong with the board. Maybe, try getting a replacement board here: https://www.ebay.com/itm/154323420288?ch...
by
Add a comment
Add your answer
Corey Ferreyra-Peterson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 20
All Time: 509
