An old, and now resurrected Polaroid land camera that was originally produced from 1972 to 1981. Saved by the previously called Impossible Project, it was the most iconic Land camera to ever be released by Polaroid.
2 Questions View all
Does the Mako Driver Kit contain the tools need to repair the SX-70?
The SX-70 requires a 1mm by 1mm square screw driver. I’m not sure whether the Square screw driver in the “Mako Driver Kit - 64 Precision Bits” contains the tool I need? Could someone confirm “Square 1” is 1mm by 1mm?
Add a comment
1 Answer
Hey, Garry! After some extensive research I can confirm that the square 1 bit in the Mako Driver Kit is NOT 1mm by 1mm. That said, the square 1 bit is about 2mm by 2mm, twice the size of the square bit needed for the SX-70.
As an added bonus, I also found 2 store page links that sell this particular screwdriver bit:
  1. Here is one on eBay...
  2. and another from Etsy
the eBay one uses a circular screwdriver socket, yet more easily available, while the Etsy one uses the standard 1/4" hex shank, but it's low in stock.
I hope you find this helpful!
-RG
Add a comment
Add your answer
Garry will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 26
All Time: 295
