The Bose Wave Radio AWR1-1W, also known as the Bose Wave Radio I, was released in 1993. A countertop AM/FM radio system with a high performance stereo tuner and two independent alarms.
39 Questions View all
My Bose Wave Radio makes distorted humming when plugged in
This question was asked already but maybe I have more luck than the previous person. When I plug in the Wave Radio it makes a distored noise. I assume there is a electrical issue. Is it possible to save it from the trash?
1 Comment
@rahhh can you post an audio file so we can hear what it sounds like? You will most likely have to take it apart, so post some good pictures of your circuit boards etc. That way we can see what you see.
Adding images to an existing question
Failed electrolytic capacitors are a possibility but one cannot rule out bad audio IC's on the amplifier circuitry.
by
Add a comment
1 Answer
Most Helpful Answer
Can you open the radio and check for any leaky or bulged capacitors? I have attached a picture below for reference.
Score 2
Add a comment
Add your answer
r z will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 706
