Repair documentation and service information for Hisense televisions.
145 Questions View all
red power button blinks 19 times
We have a 75in a couple weeks ago it was a black screen with sound I reset it by unplugging it for a few minutes which seemed to do the trick however I turned my tv off ran some errands came home and “tried” to turn the tv on and nothing happens my red power button blinks 19 times and I see a faint flash on the screen and might I add the tv is only a few months old.
Score 1
2 Comments
I have this problem too , did you ever find a fix
by
@jeremytbailey How old is your TV? If it’s within warranty I’d suggest taking it back to dealer. If warranty has expired, I’d suggest taking the back off the TV and take some good, in focus high resolution pictures. Then I would make a new question here on iFixit and adding those pictures along with the question. Remember to include the exact model number of your TV as that helps in diagnosing and finding the right manuals.
by
Add a comment
Most Helpful Answer
If this TV is only a few months old, I would absolutely get in contact with the manufacturer as they appear to have a 1-year warranty and any physical repair/troubleshooting will likely void that.
https://www.hisense-usa.com/television-1... appears to be their warranty section.
If it was outside that period of time or the warranty would not cover it, I would recommend locating the specific model, likely found in a tag or sticker on the back or bottom of the TV. Once you have that, I would then looking up power-button or power-LED errors for that specific model at what I think is the correct spot here: https://www.hisense-usa.com/support
That will likely narrow it down significantly or tell you exactly what the specific issue is.
Best of luck.
Score 1
2 Comments:
I am have the exact issue with my 75 inch
by
The same thing happened to my Hisense 65 inch TV last year. I had a warranty so they came and replaced the power board I think. And now again!! 1 yr later the exact same thing is happening again!!! Hisense is garbage!
by
Add a comment
try to follow the method on this site. I think this can solve your hisense tv problem: Hisense TV Wont Turn On Red Light Flashes
Add a comment
Add your answer
Alice Suter will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 35
Past 30 Days: 199
All Time: 5,417
