FLIR FX is an HD security camera with wireless Wi-Fi monitoring by FLIR Secure.
4 Questions View all
My surveillance project, I understand just enough to get in trouble
So the project I'm working on, I'm using 4 cameras, I have purchased a ZOSI H.265+ 5MP Lite CCTV DVR 8 Channel Full 1080p, it doesn't come with a hdd or camers, so I was going to purchase
Western Digital 4TB WD Purple Surveillance Internal Hard Drive HDD - 5400 RPM, SATA 6 Gb/s, 64 MB Cache, 3.5" - WD40PURZ
and
ZOSI 1080p Dome Security Cameras (Hybrid 4-in-1 HD-CVI/TVI/AHD/960H Analog CVBS),2MP Day Night Weatherproof Surveillance CCTV Camera Dome Outdoor/Indoor,Night Vision Up to 80FT
I just don't know if this will work, am I missing something? My knowledge level is probably a minus something out of 10, could really use help. Thank you everyone.
Score 1
2 Comments:
Oops sorry I meant to add,
Expense is an issue which is why the equipment isn't the most expensive
by
Add a comment
1 Answer
The only issue is the size of the HDD. I can't find any info on that but I have not seen 2.5" surveillance drives so it is a good assumption it takes a 3.5" drive. So, you should be good to go. Check your manual.
Since you are using the same mfg cameras, there should not be an issue with that.
Good luck.
Add a comment
Add your answer
Neil A Jones will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 133
