Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
243 Questions View all
Both Cameras not funcitoning after sceen repair.
It’s an odd situation where both cameras are not working at the same time. We had the screen repaired and since then when i go into the camera app, it remains black. It’s odd b/c I can switch between cameras in the app but it’s all dark. Are the cameras connected to the same location somewhere on the board or am I missing something? The repair guy said it was a software issue that if the apple product didn’t recognize an OEM part it would stop working. Any thoughts on this?
Score 1
Add a comment
Chosen Solution
Try disconnecting one camera at a time. I would start with the front one first as this would have been the only one touched during the screen swap. If the rear camera starts to work with the front one disconnected you have found the problem.
Score 2
8 Comments:
Thank yoU! I'll give it a shot.
Apprecate the quick reponse!
by
I doubt it's a software issue, especially if it occurred immediately after the screen replacement. And I am generally skeptical of front facing camera/sensor assemblies on replacement screens. My thought is also that that's the issue. Since the cameras communicate to each other, even though they use different connectors, a bad front camera could take out both.
by
Happy new Year!
THank yo uboth for the responses. I checked the connection for the front camera, took it all out and reinstalled it. Still no resolve. Should I buy a replacement front camera assembly and replace? Would this be the next step?
by
@samjfixit So is the rear camera working when the front one is disconnected? If it is a replacement front camera should fix your problem.
by
I disconnected the front camera and checked, the rear still did not work. I noticed something odd that i didn't catch before. The flash isn't working either. I tested by turning on the flashlight, and no luck. Any other thoughts or should I plan to replace both front and rear cameras?
by
Show 3 more comments
Add a comment
Did you faced any of this issues? after screen repair.
Common issues:
  • The camera seems to be frozen
  • Black screen on the back camera
  • The camera app is frozen
  • Out of sync flash
  • Missing options
Close the Camera App
sometimes the camera app on your iPhone does not get loaded properly, which causes the camera black screen problem. In that case, fix the issue by closing the app of the camera forcefully.
Switch the Front or Rear of the Camera
This trick may help you to deal with the black screen problem without going to an iPhone repair workshop.
Switch off the ‘Voice-Over’ Feature
It sounds surprising that the black screen issue is observed when Voice-Over feature is on. You can simply resolve this issue by following some steps. Go to the phone Setting>General>Accessibility and turn off the ‘Voice-Over’ feature. After that, wait for a while and again launch the camera app.
Restart the iPhone
The common way to fix iPhone black screen camera issue is to reset the power cycle of the device by pressing the Power (Wake/Sleep) button of the device for a few seconds.
Update the iOS Version
There are high chances of a black screen issue on the iPhone due to the outdated and unstable version of iOS. To fix the problem by updating the iOS version in the mobile device.
I hope you’ll find it helpful.
Thank you!!!
3 Comments:
Hi Thank you for your tips. I've tried all of these before with no resolution :(.
by
Hey Sam,
Just curious if you ever got this taken care of?
I am now having the same issue.
appreciate your help
by
I ahve the same issue. Changed the screen and the phone worked amazing for a week or two face id and everything. I updated my phpne to ios 17.wtv and now neither cam works
by
Add a comment
Add your answer
Sam will be eternally grateful.
Past 24 Hours: 15
Past 7 Days: 74
Past 30 Days: 299
All Time: 3,498
