Learn more about the Jenn-Air JFI2589A** refrigerator, a bottom freezer style refrigerator with ice through the door, automatic defrost feature, and equipped with an anti-sweat heater switch. This page covers information for model numbers matching the pattern JFI2589A**.
2 Questions View all
Trying to locate the location on the water inlet valve.
I am trying to locate the location on the water inlet valve. It is not located at the rear bottom. It is a jennair model JFI2589AES
Add a comment
1 Answer
Chosen Solution
Hi @hbc6415,
Here’s a link that shows the location of the dual water inlet valve part #67006322 in your model. (supplier example only)
Here’s the tech sheet for the refrigerator which may also help as it shows how to run the diagnostic tests for all the components. The wiring diagram might also come in handy if it is an electrical connection problem
Score 2
Add a comment
Add your answer
Scott Wells will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 11
All Time: 46
