Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
56 Questions View all
JVC HR-D721EN black image only sound
hello, from uruguay
I have two vhs jvc version HR-D721EN and both play with sound but black image, I already cleaned the heads and it's still the same, if I fast-forward there you can see the rain but then it's black with the play logo. any idea how to repair it or a circuit that is wrong.
here a picture
thanks
spanish:
tengo dos VHS jvc HR-d721EN, y ambos cuando pongo un casette a reproducir solamente se oye el sonido con la imagen en negro y cartel de play, ya le limpie los cabezales y sigue igual, bloquea la imágen
si le reproduzco y adelanto ahí si se ve la lluvia como que quiere verse pero luego vuelve a negro, alguna idea de algo que este mal para reemplazar
gracias
Score 1
Add a comment
Most Helpful Answer
In all likelihood it a dirty Video Heads problem. Did you use a 'Wet' type Head cleaning cassette?
Score 2
2 Comments:
Yes, I already cleaned the heads and it continues the same
by
How did you clean the Heads? Did you use a Wet Cleaning Cassete, or a Dry Cassette?
Sometimes Cleaning Cassettes are not very succesful in removing the dirt on the video heads. The head has to be Manually cleaned, using a chamois leather cloth and iso-propyl alcohol.,
by
Add a comment
Thanks a lot for the helpful information you bring. Hope you will always give everyone as many great posts as possible in the future.
five nights at freddy's
1 Comment:
hahaha hahaha hahaha hahaha
by
Add a comment
Add your answer
maricelada will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 64
