Repair information for Sharp televisions.
107 Questions View all
My TV has stopped responding to both my remote and onboard buttons.
My Sharp TV (LC55P6000U, G172055) suddenly stopped responding to remote commands with the exception of the power button. Now the onboard controls as well (except power). I did a hard reset on both the TV and the remote. It powers up, but if any button is pressed (whether remote or onboard) a spinning icon (waiting/busy/buffering) appears for a few minutes and then just disappears.
If I have my Xbox turned on, the TV will display it when powered up. But I can’t change volume or access menu etc… The remote has good batteries and the IR is working (checked through phone camera). I’m stumped! Is this a failing board? A known quirk?? Any help is greatly appreciated!
Score 3
6 Comments
I am having same issue, did it fix for you? If yes, how?
by
i’m also having this issue. any fixes?
by
Must be common. Happening to mine too. Any suggestions appreciated. I feel I've tried everything.
by
Same problem just starting on Apr-30-2023. Any help? Leo Chapa.
by
@lodegariochapa same TV? Error like this is usually caused by a bad IR board.
by
Show 1 more comment
Add a comment
Most Helpful Answer
Hi @nickydanger ,
Try a factory reset and check if that works.
Take heed of the information at the top of the page about how doing this will delete all personal info, customized settings and installed apps in the TV and restore it to its factory default condition
Score 1
2 Comments:
this is not working for me. i think since the tv isn’t responding to the onboard buttons, this is not a viable option for me. :( PLEASE HELP
by
Did you ever find a solution?
by
Add a comment
Hello, I'm unsure if you still have your TV. Mines did the same thing the other day. I called customer service today which didn't help. My 20 yr. Old came in the living room while I was on the phone and said did you try to unplug the TV for at least 30 sec. I hadn't done so yet. I just messed with the remote and the TV bottoms. He unplugged it and it's working again.
Score 1
1 Comment:
@neish52055
I do still have mine, but it still doesn't work. At first unplugging it did work, but it would stop within a few days. After the third time I was never able to get it to work again. I was quoted $200 from a local repair shop so I just went out and bought a hisense for less on black friday... it's a shame that it's uneconomical to keep old devices running but it is what it is I guess.
by
Add a comment
Add your answer
Nicholas Armstrong will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 124
All Time: 4,372
