The General Speedrooter 92R Drain Cleaner is an auto-feed drain cleaner 100' x 5/8" from General Pipe Cleaners. Released in 2010. Model number: HDPS92EO.
3 Questions View all
rescue a 5/8 cable
I have a 100’ drain snake that kinked about 15’ in from the tip, so I cut the cable back and used a quick fix to replace the end. Is there a way I can connect 2 cables together to replace the piece I cut off? rather then replacing the whole cable.
Add a comment
1 Answer
Most Helpful Answer
General Pipe cleaners has a "Quick-Fix" tip replacement you can purchase.
Score 1
Add a comment
Add your answer
JT Hess will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 139
