Trying to replace water pump in chilipad cube …. Can’t find replacemen
Can’t find replacement part for water pump in chilipad.
I found this pump that has similar specs as the original one and the inlet and outlet diameters are the same. The model is jt-180a and you can get it from Amazon or aliexpress (both seem to come from China), you will have to splice the old power cable to the new one as the connector is different.
Water Pump DC 24V Brushless Low Noise Water Pump JT-180A-24 Brushless Motor for Solar Water Heater Fish Tank Fountain Pond https://a.co/4WkOiNy
I replaced the water circulating pump with Amazon P/N: JT-180A-24 (took 3 weeks for delivery). Note that the inlet and outlet (and pump size) are WAY smaller than the one installed. I spliced the wiring (Red goes to red), I built up the diameter on the pump water connections with self-fusing silicone tape (flexseal is one brand, DUCK is another). I made a mounting base from clear plastic that matches the footprint of the old pump, transferred the silicon mounts, and secured the pump with 2 big zip ties. Check carefully for leaks - I had to use 2 zip ties on each water connection to stop the leaks. I ran the cube overnight with no leaks.. no fault codes, and minimal noise. THANK YOU JORGE L ROSALY!!!!
@Ken Vogel good to know, I had not ordered as mine is still working. So flex seal works to get it to the appropriate diameter?
If you took pictures, I'd love to see them.
I bought the linked pump, and it’s not even close to being the same size as the one in my ChiliPad
I bought the linked pump, and it’s not even close to being the same size as the one in my ChiliPad.
Look on aliexpress, there is no high tech in this thing it's basically an aquarium water cooler. The pump is just an aquarium water pump!! You can probably find the original pump on aliexpress if not match the pump specs to another aquarium water pump.
I picked up this pump from an online retailer. Minimal sizing down with a pocket knife on the offshoot nozzle was all that was needed to get the hose to fit. Here’s the link: https://coldandcolder.com/collections/fe...
Past 24 Hours: 2
Past 7 Days: 33
Past 30 Days: 151
All Time: 2,082
2 Comments
Were you able to find a suitable replacement for the pump? If so, what you buy/where?
by Jorge L Rosaly
My coller water pump is dose not work
by Ankit malviya Malviya
