Apple's top-of-the-line smartphone for 2020. Announced on October 13th and released November 13th, the iPhone 12 Pro Max sports a 6.7" OLED display, a triple rear camera system with LiDAR, and 5G connectivity. Successor to the iPhone 11 Pro Max.
114 Questions View all
iPhone 12 Pro Max Screw Specs?
No matter where I look and what videos I watch the size of the screws is always omitted.
What are the screw specs for the internal screws for the iPhone 12 Pro Max.
Screw Size(ie: M1.5, M2), Screw Lengths, Torque?
Score 1
Add a comment
1 Answer
@andyg0795 that is the trouble with all the guides and repair videos. Everybody measure the length of the screws but nobody takes the time to at least measure the diameter which would lead you to the screw size. Even the Apple parts list does not make any mention about it, nor does any of the resellers. The only way for you to get that information would be by using a caliper and measuring the OD of the screws as you remove those. If you do not have the screws you may have to purchase a complete set of replacement screws something like this and use the guides to replace the screws. iPhone 12 Pro Max
Add a comment
Add your answer
Andrew will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 583
