Apple's top-of-the-line smartphone for 2020. Announced on October 13th and released November 13th, the iPhone 12 Pro Max sports a 6.7" OLED display, a triple rear camera system with LiDAR, and 5G connectivity. Successor to the iPhone 11 Pro Max.
112 Questions View all
LiDAR sensor not working - is it the sensor or a board problem?
I recently stumbled upon an iPhone 12 Pro Max with an broken LiDAR sensor. The “measure’’ app instantly freezes, and no 3D scanning app detects input from the sensor. All other components in the phone work great and all camera’s work in their normal modes. There also isn’t any excessive power drain or heat generation like sometimes happens with shorts. It also boots normally. I did order a replacement LiDAR sensor, but it will take a while for it to arrive. However, I am currently wondering if it could be related to the power circuit on the mainboard. There’s of course always a chance that it is an board related problem, but how likely is it that it’s an board problem?
Score 4
Add a comment
Chosen Solution
without some sophisticated test equipment it is a parts jockey fix.
The sensor is the obvious first choice.
Score 2
3 Comments:
I’ll probably just have to wait until the part arrives to be sure. Luckily it’s dirt cheap at only €15 so I got nothing to lose.
by
Did you fix it???
by
Did you fix it???
by
Add a comment
It sounds like the sensor is faulty.
Score 1
Add a comment
Add your answer
Lester will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 115
All Time: 3,673
