Apple's successor to the 30-pin dock connector. This cable has been bundled with most Apple mobile products since 2012-2021
8 Questions View all
Why are there 8 cables in that Lightning extension?
I'm looking at a Lightning extension cable (with a female plug on one end and a male plug on the other) .
I would like to solder it to a standard Lightning cable (the 8 pin plug) which has 4 cables in it.
But if you look at the photo of the extension, there are 8 cables, in the following order:
black - white - green - yellow - red - purple - orange - blue
The standard 8-pin has 4 cables: gray - green - white - brown
It seems I have to solder every pair of cables from the extenion, to one cable from the 8-pin end.
But which combinations of colors should it be?
Add a comment
1 Answer
A Lightning extension cable should have eight wires that feed through to the other Lightning connector. It appears you are trying to make a conversion to USB-A connection, that cable only have four wires.
3 Comments:
Thanks for your response.
Yes, basically the other end of that extension is a Male lightning plug that you plug into an iDevice. But it is wobbly and I would like to replace it with a more robust genuine Lightning cable. (essentially cutting the USB-A end of that genuine USB-to-Lightning cable, and soldering the Lightning end onto the extension plug pictured above.
by
Why is it that an extension has 8 wires, but the USB-to-Lightning cable has 4?
by
@Alex222 - Cables have different purposes!
The number of wires will always be the lessor matching the number of contacts of the connector with fewer contacts. So in your case USB-A is either USB-2 (4 contacts) or USB-3 (8 contacts) wiring.
Presently Lighting to USB-A is four wired. A straight through Lighting cables will have eight wires.
For example there are six different USB-C cable setups! Wait until you try dealing with them ;-{
by
Add a comment
Add your answer
Alex222 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 32
All Time: 520
