Released June 2017, the iPad Pro 10.5" replaces the 2016 iPad Pro 9.7".
145 Questions View all
What are sensor(s): TT0D TT1D TT2D TT3D TT4D TT5D TT6D TT7D TT8D
Ipad pro 10.5 restarts every 3 minutes. Only known issues are prior damage to an fpc connector on the motherboard and a replaced LCD flex cable. Any ideas about these sensor(s): TT0D TT1D TT2D TT3D TT4D TT5D TT6D TT7D TT8D?
1 Comment
Any suggestions? Ideas?
by
Add a comment
1 Answer
Chosen Solution
I have not heard of these specifically, but if it's indicating these sensors are missing (hence the reboot), and based on the history of this device I would suspect VERY strongly that these sensors are all in the Display. Apple's naming conventions for these sensors are not made public, but they tend to use a pretty normal set of abbreviations. And this would make sense to me (D at the end for Display).
I don't have much in the way of technical documentation for these specific units, but my suspicion is that whatever line the data from sensors is coming in on is the issue. Could be the FPC, or the the replacement cable. Make sure all your solder joints on the FPC are sound. Check Diode mode readings for whatever connector was replaced. You can find expected readings at https://logi.wiki/index.php/iPad_Diode_M...
Score 3
1 Comment:
The flex cable wasn't completely soldered.
by
Add a comment
Add your answer
Willow will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 50
All Time: 975
