The Volkswagen Transporter T6 is a mid-sized van produced by the German automaker Volkswagen Commercial Vehicles.
3 Questions View all
Volkswagen T6 transporter glow plug light and limp mode
Hi
My Dads Volkswagen T6 transporter is giving him a light and going into a very slow limp mode
Does anyone know what it could be
It’s not a very old machine it’s only about 30,000miles on the van
Any answers will be greatly appreciated
Thanks
Add a comment
1 Answer
Chosen Solution
Hi @hellomacos
Get the vehicle's ODB2 port scanned for any error codes.
If there are any codes they will tell you what the problem is. It is the quickest way to know what the problem is.
Places such as AutoZone etc in the USA do this for free
Here's an image to show where it's located
(click on image to enlarge)
There's lots of info online about what VW T6 ODB2 codes mean once you know what the codes are.
Score 2
6 Comments:
Hi @jayeff
We have done the OBD2 check and it doesn’t show any codes
Any other ideas
by
@hellomacos
I don't know about VW but if the glow plug light is on it indicates that the glow plugs are warming up the fuel/air mixture in the cylinder for more efficient starting on cold engines, but then it should turn off after a very short time
At least this is what they do in my Forester diesel. The light is always on on starting and lasts for about 2-3 seconds before going out..
So maybe if the glow plug light stays on it may indicate a problem with them or a sensor that determines when to turn them off. I don't know. Although you would think there would be a code if that happened.
Unless of course the light means something else when coupled with limp mode but you didn't say that the check engine light was also on.
A quick search online shows that a glow light on/limp mode condition seems very common with VW T6 and there are lots of different causes - egr problem being the most favoured although not always the reason.
Make sure that there is sufficient coolant and oil in the engine because egr problems can affect both.
Is the vehicle still under warranty at all? 30,000 miles is not much mileage.
by
@jayeff
The check engine light was on but went off and the glow plugs lights came on
And I forgot to say but the light is flashing
by
@hellomacos
As I said lots of T6 glow plug info online.
Here's just one link where it seems that there can be multiple reasons for the light to blink and the vehicle to go into limp mode. Not all the causes shown were on the same vehicle ;-)
Also very strange that there was a check engine light but no stored DTC codes from the OBD2 port
by
Thanks for the link
It’s greatly appreciated
by
Show 1 more comment
Add a comment
Add your answer
HelloMacOS will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 151
All Time: 5,191
