How to change rear battery cover?
I want to change the rear battery panel because it's got some using marks and looks really bad
ybo.shooter check this video you need a heat gun as your main tool. Temperature on the back cover should be around 70deg C to loosen the adhesive. Not complicated just a bit tedious.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 481
