Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
243 Questions View all
iPhone re start every few minutes how to fixit?
because it keep restart
tell me how can i fix it please
_____________________________
{"bug_type":"210","timestamp":"2022-05-16 19:44:27.00 +0300","os_version":"iPhone OS 15.4.1 (19E258)","incident_id":"C9C6E5DE-CA40-46A0-B9B3-A5A11E8CEEE4"}
"build" : "iPhone OS 15.4.1 (19E258)",
"product" : "iPhone12,8",
"socId" : "0x00008030",
"kernel" : "Darwin Kernel Version 21.4.0: Mon Feb 21 21:27:53 PST 2022; root:xnu-8020.102.3~1\/RELEASE_ARM64_T8030",
"incident" : "C9C6E5DE-CA40-46A0-B9B3-A5A11E8CEEE4",
"crashReporterKey" : "dbae2bb8b397cf3be1297c5d6ca6c6205f4bcc83",
"date" : "2022-05-16 19:44:27.82 +0300",
"panicString" : "panic(cpu 1 caller 0xfffffff015250448): userspace watchdog timeout: no successful checkins from thermalmonitord since load\nservice returned not alive with context : is_alive_func returned unhealthy : current 6fffffffffff, mask 1fffffffffff, expected 1fffffffffff. SD: 1 BC: 1 RC: 0 BS: 1, Missing sensor(s): mic1 \nservice: backboardd, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\nservice: SpringBoard, total successful checkins since load (169 seconds ago): 17, last successful checkin: 0 seconds ago\nservice: mediaserverd, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\nservice: logd, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\nservice: thermalmonitord, no successful checkins since load (180 seconds ago)\nservice: runningboardd, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\nservice: wifid, total successful checkins since load (180 seconds ago): 19, last successful checki\nDebugger message: panic\nMemory ID: 0x1\nOS release type: User\nOS version: 19E258\nKernel version: Darwin Kernel Version 21.4.0: Mon Feb 21 21:27:53 PST 2022; root:xnu-8020.102.3~1\/RELEASE_ARM64_T8030\nKernel UUID: 5F341516-AD27-3584-B1A5-883AF00B2DCE\niBoot version: iBoot-7459.102.5\nsecure boot?: YES\nPaniclog version: 13\nKernel slide: 0x000000000b834000\nKernel text base: 0xfffffff012838000\nmach_absolute_time: 0x1171be47b\nEpoch Time: sec usec\n Boot : 0x62827e9a 0x000a0c89\n Sleep : 0x00000000 0x00000000\n Wake : 0x00000000 0x00000000\n Calendar: 0x62827f55 0x0002fe8a\n\nZone info:\n Foreign : 0xfffffff0fc7d4000 - 0xfffffff0fc7e4000\n Native : 0000\n Bitmaps : 0xffffffeb03c6c000 - 0xffffffeb04d28000\n\nCORE 0 recently retired instr at 0xfffffff0134cc0a0\nCORE 1 recently retired instr at 0xfffffff0134cac10\nCORE 2 recently retired instr at 0xfffffff0134cc0a0\nCORE 3 recently retired instr at 0xfffffff0134cc0a0\nCORE 4 recently retired instr at 0xfffffff0134cc0a4\nCORE 5 recently retired instr at 0xfffffff0134cc0a4\nCORE 0: PC=0xfffffff0134c2cb0, LR=0xfffffff0134c2cb0, FP=0xffffffeb05f8bf100xffffffe000200000 - 0xffffffe600200000\n Readonly: 0xffffffe0e6864000 - 0xffffffe133530000\n
Score 2
15 Comments
Are there any panic logs? Settings >privacy>Analytics and improvements >Analytics Data. Look for anything that says “panic full”.
by
@areeve yes . i find it. more than one
by
What do they say? Adding images to an existing question @NARA PRIN
by
@areeve panic-full-2022-05-16-194427.000.ips
by
by
Show 10 more comments
Add a comment
Most Helpful Answer
This error log is telling you that one of the sensors on the charge port assembly is faulty. It is trying to communicate with mic1 which it does every 3 minutes. If it doesn’t get a response it will restart the device. A new charge port should fix the problem. You will need to purchase this part from a reputable store and you can follow this guide.
Score 4
4 Comments:
@imicrosoldering so sensor mic1 does not refer to the mic but the board where the mic is attached to.....Awesome!
by
Yes exactly. This panic-full log points the panic string to thermal sensor circuit. This is a charging flex problem. I see this iPhone restart has been a very common problem so I decided to post it on a small blog so everyone can have access to everything about iPhone restarts and panic logs, full information you can access it from https://joseftechnologies.blogspot.com/2...
by
@oldturkey03 mic1 is located on the charging connector flex cable
Mic2 is present on the power button flex, that is for the iPhone 11 series
by
I am curious, I am having the exact same issue. I have replaced the charge port with both an after market, as well as an Apple OEM charge port, and the phone is still restarting with the same panic message. Is this an issue with the board itself just not getting the appropriate signal?
by
Add a comment
Hi
A restarting iPhone can be caused by many things but the most common thing is a bad battery which can be purchased from the ifixit store for a very reasonable price
Hopefully this answers your question
If it hasn’t please give me a shout
Score 2
Add a comment
Hi everyone
I have the same issue after water damage but the matter is my iphone charge normal and i can record my voice normal!
how even that possible if the iphone cant connect to mic?
Add a comment
Add your answer
NARA PRIN will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 65
Past 30 Days: 281
All Time: 7,601
