Released in Sept, 2018 by OPPO
27 Questions View all
My phone is not turning on
Before 1 month ago my realme c1 phone was suddenly turned off then I go to for repair they changed the folder and it was working after 15 days it happened again and my phone has been turned off while charging time.
Since then my phone is still not on.
Can you help me।
Score 4
Add a comment
Try to press and hold the power button for few minutes and repeat this process and check if its works.
Add a comment
If there is lint in the charge port, the cable can't seat properly and this can prevent it from charging at all. VERY CAREFULLY use a pin or needle to check that the phone's charge port is clean.
Add a comment
Add your answer
THIS IS PAVAN KASHYAP will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 89
All Time: 656
